on the first layer i did a couple days ago i 77'd the inside of the cloth. It sticks really well, actually let me wrap the fiberglass around the edges, so that was pretty great. The problem was where i had some folds when i didn't lay it flat, when i pulled it up it pulled up the PVA film from the tape/wax. But other than that it worked great. I would say my main issue was i tried to pre trim the fiberglass and i should have left the excess on and trimmed it after placing it and than i wouldn't have had to rearrange.
I didnt notice very many bubbles at all under the first layer, in between the cloth and tape. The pva and cloth stick together pretty well. I had to use some zip ties on the nose and tail to keep those tapers tight though.
I didn't realize how much time it would take to get thru the whole process so only did the one layer. This isnt a epoxy setting up issue but just a 6 year old daughter wanted time issue lol
This morning i sanded the entire surface and cleaned it off. Than i sprayed the entire fuselage with 77. This worked really well. The tow stuck to it very very well, not even giving the glue any time to dry just immediately applying the carbon. I pulled it tight and it just stuck down without shrinking.
I did have some bubbling up in areas especially where the carbon tow crossed over itself. I worked it out as much as i could but im not going to beat myself up over it. Its my first time doing this. Im sure its not as strong as it could be, but im learning. Next time i will be sure to give myself time and do all the layers at once. Even this second layer went significantly faster than the first layer as i knew what to expect and how the fiberglass was going to behave. On the first layer i didnt realize that you need to wet it out and give it time to absorb into the cloth before it will lay down. So this second layer i would start on an area and immediately move on, coming back in a few minutes after it was plyable.
I think with this 6oz s-glass i would not super77 it next time. Whatever binder it has keeps it together very well and its not needed. And once you wet down a strip all the way down it really isnt moving anymore.
