Low cost build
chrix32
Hi everyone, I have been following various threads and now i want to build my first RC build, a quadcopter. I have a budget of 400$
I think this setup can work fine, what think guys?
HJ 450 quad Frame
http://www.amazon.com/NEEWER®-Usefu...qid=1376814004&sr=8-1&keywords=450+quad+frame
x5 Sunnysky motors 2212 1250kv (one for the crash box)
http://www.amazon.com/Sunnysky-1250...=UTF8&qid=1376813910&sr=8-2&keywords=sunnysky
x5 30A ESC Hobbyking Blue Series (one for the crash box)
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=26497
KK2.0 board
http://www.hobbyking.com/hobbyking/...2_0_Multi_rotor_LCD_Flight_Control_Board.html
Fpv kit 900Mhz 200mW
http://www.hobbyking.com/hobbyking/...0mW_Tx_Rx_1_3_inch_CCD_Camera_PAL_420TVL.html
x2 3300mah 3S 30C Lipo
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=15003
x2 800Mah 3S 20C lipo (for fpv tx and rx)
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=18636
already have 9x radio tx and rx
Cyberdactyl
Misfit Multirotor Monkey
#2
Looks good to me. Throw in some 9" props and you're good to go.
If I were to suggest anything, and this is not critical in the least, is to mention securitycam2000 has a similar but slightly better FPV cam over that bundled sony cam in that kit. Here's a guy comparing the HK one to the securitycam2000 one. BUT, as I said, it's close to the entire HK FPV kit, so it's merely a suggestion. Maybe something to look at if you break the HK cam.
Cyberdactyl
#3
Oh. I should've mentioned, I'm not just suggesting this from a review. I bought one a couple weeks ago and got it quick about 5 days ago and have been messing with it. If you follow this forum, you may have seen I lost a quad in the massive woody area behind my house, which had my Foxtech V3 on it.
This Sony CCD is much better FPV-wise than that cam. Albeit the V3 had 1080P record capability. But the Sony CCD HAD is MILES better in low light than the Foxtech V3. So much so, I believe I'll be able to do some night flying with it.
