dkj4linux
I'm not sure I understand, but won't the bolt block some of the travel ? If I look at the pictures with your fingers undeside, even if the shuttle is at its highest position, the bolts would hit them at the gantry slides sideways.
Would'nt it make more sens to block the bolt on the shuttle, and have the bearings on the gantry ? that way, as the shuttle is lifted, the bolts don't scratch/limit the surface underneath.
The idea here is that the needle cutter/laser/etc doesn't actually require a lot of Z-axis travel in operation... once the business end of the tool is properly positioned above the work piece. Envision mounting the needle cutter so that it's needle guide extends below the heads of those guide rods (bolts)... even at the highest position. Yes, the bolt heads could be positioned quite close to the surface of the work piece but as long as they clear, they clear... they'll never move or interfere with movement of the cutter head over the work surface.
The guide rods could, as you suggest, be firmly fixed to the shuttle and the printed bearings mounted to the carriage body... the guide rods would then move with the tool head and never be in the way. But, in this case, the relatively large/complex printed carriage was developed first... and it was easier, at the time, to simply fix the guide rods to the carriage -- for visualization of range of motion primarily -- and then come up with a shuttle/bearing system to fit.
Remember, I'm just feeling my way along here... :black_eyed:
