Steps 17 through 22 - Finishing the Fuselage
I know I still have the wings to do as well as the horizontal and vertical portions at the tail but, man, does this feel like an accomplishment. Even with the mistakes.
Step 17 - Basically fitting all the formers of the fuselage into the sides but not gluing them. At this point - and in the Christmas spirit - I kept singing to myself "It's beginning to look a lot like a fueslage". Now that I got that song stuck in your head.....
Step 18 - Attaching and gluing the bottom. This turned out much harder than I imagined it would in terms of keeping everything lined up so I did the first two sections separately (makes sense) and then the back in small sections to keep it lined up.
Steps 19 through 22 - This involves setting the pushrod housings through the holes in the fuselage, tacking them in place and then making sure all joints are glued.
I screwed up a little here and should have slowed down maybe but when all was done I couldn't figure out why they had places for servos in both the middle of the aircraft and the back. There wasn't anything in the instructions about the difference but it was clear in the laid out plans that you only need the middle placings (and the pushrod housings) if you're using the steerable nose wheel. No biggie since I can trim them down and ultimately hide them.
Next up--- The Wings
