French
Construire Voler S'écraser Répéter
I'm still trying to learn about the FRSky equipment, and planning a build (hopefully, I'll be able to actually build it )
I'm thinking of running an X4R-SB and lux FC. Can I hook the S.port to one of the FC's uarts (T2) to get telemetry data back to the radio? Does the uart work that way? For me, the critical function is the Vbat, but I also may like the ability to receive other data from the FC. (Honestly, I don't know everything that's available.) I understand the X4R also has an analog voltage plug. Should I just do that and forget about the S.port? Can Ireveive a lowest cell voltage if I go through the FC?
I'm also planning on using an rrosd pro pdb and the analog rssi from the X4R to the rrosd.
Thank you!
Thank you!
