I destroyed the carbon fiber spar in my Wing Surfer from Nitroplanes (Same thing as a Bixler) when I borrowed someone else's tx and neglected to check that the control directions were correct. Since then I've been using a large bamboo skewer (about 5mm dia and 30"ish long). This works, but is quite flexible.
I managed to snap the bamboo spar while out flying this evening. I was puttering around at low speed and near ground level when I decided to go full throttle, pull up into a loop with a snap roll at the top. The snap roll broke the spar in two, the wings came out of the fuse, folded back and she went down from about 50 feet. Surprisingly, damage is very minimal.
I've had no luck finding a 6mm CF rod locally and am wondering what I can do to stiffen the bamboo. I've already tried covering with gorilla tape, but that didn't work so well. Thought about wrapping with thread and covering with epoxy, but that is A LOT of wrapping! Any ideas?
Thanks!
Thanks!
