Making EPS serious strong on the cheap and revising the nutball/flying potato chip.
HappyRCFlyer
Update with the anhedral, with more test flights on the chuck glider, directional control this time on the control surfaces it's going to need ailerons or elevons for that element. It's amazingly stable and the glide ratio is significant, I'll be doing up an RC version of it in this configuration. Showing a bent tip on the shot to show some degree of deflection/aileron type of control. I still was amazed just how smoothly it fly's going this route, much stability without the normal wobble going on with lift body's when they are about to stall.
HappyRCFlyer
I'm getting another one finished up this eve to ship out to a customer RTF format.
HappyRCFlyer
Thanks for the encouragement on trying more with the headstrap Bisco.
HappyRCFlyer
Thanks, the last round of the flight was keeping it within a simulated area of my back yard where I want to be flying it at. It's tree lined and much smaller so I'd rather practice without tree interference upon. It was also the second official flight and just as with maidens, you don't push things to far, nor too long so you can see if anything loosens up or needs adjusting before pushing it further on future flights. I can't count how many times people do not take these necessary steps and complain their newly build/bought plane malfunctioned on their first flights. My esc is getting tossed, once it warms up it won't fully power down the motor.
bisco
agreed, including myself :( I get so antsy to get out and fly, I don't do enough checks.
HappyRCFlyer
My last pushing it was on my Extra 250. The wing came loose from the fuselage slot so it was just sliding around the whole flight.
HappyRCFlyer
I have the next Cylon version mostly done up last night, I'm calling it the A version, short for Anhedral or "after" since the dual rudder system was something I did on another disc shortly after doing up the original in 2004.
I'm using a different foamboard rather then the dollar store stuff on this one, called Pen and Gear from Walmart. It's a bit heavier and more dense, the laser cutter was required to have a significant increase in heat to cut through it and the paper takes a lot of effort to remove. The finish though is outstanding.
HappyRCFlyer
The second version is ready to maiden. It's flying weight is 496 grams, the other version is 416, so basically one pound flying weight, acceptable for sure.
