Help! Making my first Quad!
just wondering...you said keep it away from magnetic fields...what about the motors?
You can only do so much.... But yes.
Ardupilot actually has a way to Check/calibrate for Current and motor interference.... INAV does not.
Easiest test is to disable the mag and see if that helps.
Okay i tried doing the calibration away from metal and it seems a lot better! It still does do a very slow back and forth thing but I have a a feeling that's just the GPS center as its getting its bearings...It doesn't keep moving across the the screen now. Does that sound right?
You can even set up a switch to fly inverted.... including when in all missions and scripts.
