Help! Making my first Quad!
Hmmm. Don't need that for the ArduPilot MissionPlanner. Never done missions with INAV, just RTH and telemetry.
Ah wonderfull, bing maps is being retired and will become azure maps in june. That will probably mess a few things up. LOL
What tab is are the beeper settings in in Inav?
LOL.... I just ran into that problem last week. My beeper wasn't working, but the motors were beeping instead. If you are using Dshot, you can set up Motor beeping. Not many options. The "beeper" has always worked For Planes
# get beep
dshot_beeper_enabled = ON
Allowed values: OFF, ON
dshot_beeper_tone = 1
Allowed range: 1 - 5
And:
# beeper
beeper RUNTIME_CALIBRATION
beeper HW_FAILURE
beeper RX_LOST
beeper RX_LOST_LANDING
beeper DISARMING
beeper ARMING
beeper ARMING_GPS_FIX
beeper BAT_CRIT_LOW
beeper BAT_LOW
beeper GPS_STATUS
beeper RX_SET
beeper ACTION_SUCCESS
beeper ACTION_FAIL
beeper READY_BEEP
beeper MULTI_BEEPS
beeper DISARM_REPEAT
beeper ARMED
beeper SYSTEM_INIT
beeper ON_USB
beeper LAUNCH_MODE
beeper LAUNCH_MODE_LOW_THROTTLE
beeper LAUNCH_MODE_IDLE_START
beeper CAM_CONNECTION_OPEN
beeper CAM_CONNECTION_CLOSED
Command line fun!
# beeper list
Available: RUNTIME_CALIBRATION HW_FAILURE RX_LOST RX_LOST_LANDING DISARMING ARMING ARMING_GPS_FIX BAT_CRIT_LOW BAT_LOW GPS_STATUS RX_SET ACTION_SUCCESS ACTION_FAIL READY_BEEP MULTI_BEEPS DISARM_REPEAT ARMED SYSTEM_INIT ON_USB LAUNCH_MODE LAUNCH_MODE_LOW_THROTTLE LAUNCH_MODE_IDLE_START CAM_CONNECTION_OPEN CAM_CONNECTION_CLOSED ALL PREFERED
Nice, INAV devs "working on a solution" as of Jan and will have more details as june gets closer.....
It's almost june. LOL
Command line fun!
# beeper list
I am actually beginning to like cli's
Actually I use INAV or BetaFlight to do the initial flash with the file I download from AdruPilot. STM32 tools can always flash anything. Once it is flashed it can be updated with Mission Planner or Q ground control.
Yeah I have to use Qgroundcontrol because i am using linux
You mentioned the other day that Ardupilot would work with the Speedybee F405 v4 Fc.....I couldn't find the file for it....So right now I am using the Mateck F405-wing firmware that was recommended by ChatGPT and that seems to be working.....
Use the -heli version if you are using blheli.
This is in the latest 4.5.7 directory
I know it's there. I am using the wing FC
