Making my own foamboard
Matthewdupreez
yea I've been wanting to build a sea plane but the paper would just have peeled off...... now sea plane here I come...... probably an FT Angel. it's so sweet looking
Matthewdupreez
although here's a fun fact I don't live anywhere near water....... hmmm maybe I should look at one of the ones that'll also land on a runway
Matthewdupreez
Wow, nice!
What parameters do you plan on trying?
I suggest trying multiple glues and trying with and without sanding the plastic surface.
so my foam I'm cutting is about 50cm wide by 2m long and the plastic will fit on that perfectly so those sort of parameters are what I'm looking at, and I cut my foam about 3-4 mm thick. ill probably use wood glue on one and normal homemade glue on another and sanding as you suggested, ill basically carry out a science experiment
Apis
This weekend, I will try to track some 0.1mm or 0.2 mm acetate plastic down and try against depapered DTFB. I don't have a rig to measure strength, but I can do a qualitative assessment and measure weight
The Hangar
Fly harder!
do you guys know of a seaplane that will also take of and land on ground?
This one would work too:
