Yes. You can cut one yourself from craft plywood, or be lazy (like I am) and order some from the FT store. However, If you're in the UK, that might not be an option- use the free plans from another FT model, like the Corsair, to get the dimensions correct.
More progress made, not sure how the fin fixes on though, does it just get hot glued onto the top of the rear fuselage tube and into the end of it? or is a piece made up to attach the bottom of the fin to the rear of the main fuselage inside the rear tube, if not how strong is it?
another method is to build without any bevels and when the glue is good and dry you take an iron and slowly add a curve to the top and bottom. I picked up clothes iron at a garage sale for $1 and prefer that to a rc covering iron. You can even add a bevel to the vstab and hstab single layer. It takes a little practice but it really isn't that hard. There's several videos on YouTube just search for Iron fc dtfb and you'll find @battleaxes vidsI cut at 45* and reinforce the hinge with hot glue. That's pretty standard foamboard building stuff. Just be sure to keep the hinge wide open until the glue dries fully.
As for the leading edge, there's a bunch of different techniques. Easiest is to cut the edge of the top sheet at an angle (greater than 45*) after you've made the airfoil curve to have it line up with the bottom sheet. That's what most of the FT MS plans call for. Other folks will leave the top sheet alone, but glue a thin dowel rod to the double thickness of the leading edge using lightweight spackling to fill in any gaps then covering it up with hinge tape. This method reinforces the trailing edge.
One other technique (which I've had mixed success with) is to do what some of the plans from the 13th Squadron folks call for (like their Betty, for example), which is a dual bevel on both sides, then fold over using wide painters tape to hold everything together. In my opinion, that one looks the best and is super solid, but it sometimes doesn't work when the tape slips and there's a wide gap between top and bottom sheets. May want to skip that one on your first build, unless you're feeling very ambitious.
Found a small error on the plan, the spar slots in the wing don`t match the tabs on the spar at the outer end, did you find this in your build CrshNBrn? Did you just extend the slots and add foam to fill the rest of the cut outs?
