First wing half built tonight, what did you do about dihedral, on the wings or did you just guess at it?
Replacement panel made showing the difference in size, now onto the other wing panel, hope to have that made and the two joined today.[/QUOTE
Right guys apologies due, the plans are correct on the spar slots and i have one scrap wing half!When i had the plans printed they cocked up and only printed one sheet, the right wing panel one. I went back and they then printed the rest off, that first sheet has been printed over size
so i have built that wing too large, no wonder it looked a bit big for the fuselage gap as well, only discovered it when surprise surprise the left wing slots match the spares. So back to square one, today i will mostly be building both wings instead of one and a pair of new spars.
Wow! That was fast. I'd be sleeping all day if I just got back from scout camp.
I'll bet Kartman's Me-109 will look a heck of a lot better than mine. I still like flying mine and it's still holding up. It's fun to fly with the MS Spitfire- I'm trying to get someone to do some Battle of Britain streamer combat, but haven't had any takers yet.
Wings made and joined, just making the wing to fuz joing a bit neater, may go with the fairing as you have as well. Might get the tail il on later. Did you cover yours before painting, what paints did you use, brush or sprayed?
What did you skin it with? B&Q foam? If so, which one and how did it work? About to buy some and fancy building this - only allied planes in my hangar so far which seems a bit of a missed opportunity!Had a delay as one of our cars needed some work to pass it`s MOT, back on the 109 now, fuselage covered in brown paper/PVA today and canopy made, Wing will be glued on tomorrow and possibly the tailplane and fin, it will be finished in the next couple of days bar the paint, got a couple of schemes in mind but want something different from my Cambrian models 109 which is i finished in Battle of Britain colours. This foam one is a similar size and will be flown on the same size lipo so the weight comparison will be interesting.
Thanks. I’ll stock up and experiment with it. Looks promising!Fuselage skin is the grey Vitrex depron underlay, 5mm, 19 sheets for £25. B&Q also do 3mm Dial white insulation, that might do the job and with less weight as it is only 3mm, i have now got some but have yet to try it.
Just adding a bit of scale detailing now as it it technically ready to test fly, balances good on a 3000mah 3s, weight is 2lbs 2oz at the moment with the pack in it. I have made the exhausts and the tropical air filter, got the top cowling guns and wing fillets to make tonight. That will be it, just the painting to do which is one of my favourite parts, going for a tropical type scale scheme, got the paints so just got to wait for a nice day to spray it outside. I won`t be test flying it till i have it all painted and the decals applied as i want to get some nice pictures of it first.............just in case!
