Thank you sirIt's one for real flight that I downloaded off of the Knife Edge Swap Pages
@leaded50 - Wow this is really coming together.
I have been meaning to ask U since U first posted the canopy. How did U go about making this one. From what U have posted, it looks fantastic.
Thanks, I used some "plastic material"...(unsure whats actual name) and cut strips approx 3 x 3 mm. First maked a "base" on actual fit in the hatchopening. Maked the 5 bows shaped to get it correct gluedon the base , then glued in bits between. Then painted the hole framework. At end using parts from plasticbottle as "windows" (here 5 parts lengthwise) glued on.I have been meaning to ask U since U first posted the canopy. How did U go about making this one. From what U have posted, it looks fantastic.
i was thinking on doing a thermo formed canopy too... but saw it was quite easy do the shape withoutThanks. Looking for some ideas. I have done thermo forming using plastic bottles and was thinking of vacum forming using PET plastic for the P6m.The P6M-2 had a framed greenhouse style canopy that could work with way U did the Moonbat.
Correct, its glided as that. Not the lightest plane made though, because all extra the shape needed. 1050g without motors, retracts and battery, but rest intact. 1375mm wingspan, 1035mm long. 3 servoless electric retracts, + 6 servos (alierons, elevator,rudder, flaps, steering)WOW! U R just moving right along with this one. Looking good. The Moonbat looks like there is an incredible amount of lifting surface. Did it glide like it had a very light wing loading?
WOW... very neat... Maybe Flitetest Should employ you like, @Splinter189(John Overstreet)
