Me 262B-1a/U1 night fighter
Jade_Monkey07
Limited by my technology I've been looking up planes that would easily convert to 2ch pusher setup. This round I decided on the Me 262B-1a/U1 night fighter
The build took about 4 hours. It's not perfect. But it's my best resembling model yet.
Glide tests were very promising so I moved the rc gear over to it and got it all balanced. I quickly moved to 2 dimes glued under the nose instead of the single dime extended out.
Its maiden flight it was very tail heavy and sluggish. I removed the paper from the tail and it leveled out nicely, but it's very slow and barely stay in the air. First thing I tried was adding tape wing extension/flaps. This helped but The engine nacelles are a ton of drag, so sadly i removed them and just went with a flat visual facsimile of the necelle. This fixed everything now its flying perfectly, Its quick and maneuverable with a decent glide profile. Turns way better than I expected. I'll grab a video tomorrow morning. Then the paintjob to match my source photo
Flyingshark
View attachment 185343 View attachment 185344 Glide tests were very promising so I moved the rc gear over to it and got it all balanced. I quickly moved to 2 dimes glued under the nose instead of the single dime extended out.
Looks great! You could even try making the radar antenna on the nose out of thin wire or something. But if you did that they might get bent out of shape when you landed.
