MajorDiegtiariow
Hi Flite Test!!! I thought I will give you a hard project. You have already made F-22 from America, JA-37 from Europe, maybe it's time for something Russian?
Your goal is to make an EDF Su-35/Su-37 (or a mix of them, like Su-35 with canards
) from foam/depron with advanced 3D fuselage and 360 degree thrust vectoring nozzles.
Requirements:
Wingspan: up to 500mm
360 deegre thrust vectoring NOZZLES (not proppeler or moving turbines) like in normal sukhoi
Weight: up to 350g
Deatil level: like in normal version of Viggen, however nozzles have to be quite round (not Chad's flying box
Engine: 2x 28-40mm turbines
Moving: both nozzles, both rudders, both elevators, ailerons (optionally canards)
Gear: detachable
Up to 6 channels
It should have vectoring like that one: https://www.youtube.com/watch?v=WUQHgcOMSMM
I know it is a bit hard to make so small and advanced plane, but c'mon guys, you are doing even more crazy things (flying cinder block, flying microwave, flying toaster, you've put a butane afterburner into an EDF jet
If you will make it, please make also a Speedbuild kit for it, because I would want to buy it
Maybe you will name it FT Sukhoi
Requirements:
Weight: up to 350g
Gear: detachable
Up to 6 channels
