Oh i was suprised it was light on videos. How does the tweaker compare to the shreiker
There really is no comparison to make there: they are two separate classes of quadcopter.
Some people consider the 180 quads size part of the Micro class but really they're not because you can easily run 2204 motors on 4" props and at that point those copters perform just like their bigger brothers. They can easily carry gopro cameras and they make excessive thrust (we're talking in excess of 9:1 thrust/weight ratios). Not to mention they tend to weigh only slightly less than comparable 200-250mm size quads.
My lightest 4" build is a Mitsuko 4 and it is 250g without the battery. My Tweaker FPV Addiction is 311g without the battery. For comparison, my Twitchity Acro Quad (235mm) with FPV pod is 300g without battery, my Blackout (220mm) was 320g without battery. And then you have oddballs like my Shrike which is a 185mm quad but designed for 5" props and 2204 size motors, it was 275g without battery, and obviously makes tons of power for its size/weight.
I consider the real micro class to be the ~130mm 3" prop copters, which even with 1306's haven't quite reached that performance level of their bigger brothers yet. Even when you start seeing 9:1 thrust/weight ratios from these guys, they will still have trouble carrying HD recording cams because 50-75g increase in mass makes a much bigger performance impact on these when compared to copters running 4/5/6" props and power systems.
