Micro triplane
Vermillon_baron
I am making a twin motor micro triplane with micro quad motors and 6 amp escs. I want to use a bec but the escs I have don't have the red wire required. I still need to keep things light so how should I power the receiver?
Liam B
Thank you! How should I wire it in?
Solder a wire to the + and - of where the battery plugs in (make a cut in the heat shrink and run an solder it), and then solder those wires to the + and - of the 2-4s side of the regulator. Then, on the 5v side, solder a servo connector to the + and -. The red or orange-red wire on the servo connector is the positive, and the black or brown is negative. Ignore and don’t solder the yellow or white.
TazRC
Obsession, not hobby
Thanks for the diagram, TheStig4449!
Vermillion_baron: Just for clarification, you're going to want to "T" or tap into the positive and negative on the ESC side of the battery connector.
