Mig 1.44 or Rafale with two rudders? You decide!...
jmrpb
Mig 1.44 or Rafale with twin rudders? - You decide!...
With Functional Canards
(Version 2)​
This is my new Mig 1.44 or Rafale with twin rudders. It has functional canards mixed with the elevator channel and four servos. The elevators and ailerons are linked together (like elevons).
This airplane can maneuver like a 3D airplane, and it can also be very fast or very slow (canard mixing help a lot).
It has a simple way of vectorial thrust, like some of other pusher planes. It does almost any 3D manoeuvre that you can think of, with a very good vertical performance. And, of course, it is also very forgiven and stable if you want to. Most of the times, I catch it by hand on landings.
It has KF airfoil number 4 (symmetrical 6mm up and down - Acro) for aerobatics. Like you can see it works great!!
The power system is the great secret for good low speed and high speed performance.
The specifications are:
Motor: Axi 2208/34 gold line;
Propeller: Graupner 9” 6” Slim Cam (This is because the 9” 6” is perfect for acceleration from slow speed and high AoA and also have great behavior at high speeds);
Batteries: #1 Lipo 3 / 850 mA/h with 30C;
Speed controller: Jeti 8A (yes; just only 8 Amps, but this is more than enough. With this power system I can maximize my flight times around 9 minutes with 3D and Acro performance or 12 minutes plus with gentle use of the throttle stick (this is, if you can control yourself with this kind of bird ).
The ailerons and the elevators are linked together by one carbon tube.
The canards are mixed together with the elevator channel for slow flight and high angles of attack.
Roughly, the dimensions are:
Front to tail: 80 cm (overall length);
Front to leading hedge of the wing: 30 cm;
Wingspan: 60 cm;
Leading hedge swept angle (wing): 60º;
The tip of the wing (outer far part of the wing is): 12 cm (with ailerons);
Ailerons have: 8 cm (at the widest point);
Dimensions of rudder (at widest point): 18 cm tall by 13 cm wide (at the bottom);
Weight: 350 grams or ~ 12,5 oz to ~ 13,5 oz range. Ready to fly (with this set up and battery).
The front part is made of red ‘polypropylene’ that makes it almost, and I say ALMOST, indestructible. The canards are made of thin (2 mm or, approximately, 1/10 of an inch) orange ‘polypropylene’.
I hope that this brief description helps.
I will post a video as soon as possible.
It looks great in the air with this painting scheme (tiger camouflage) and it’s guaranteed that you’ll receive all the attention of other RC fellow pilots!
Check out the photos below.
Follow your dreams and fly like there is no tomorrow! :).
Happy flights and happy landings!
José Bernardo
Lisbon, Portugal, Europe
jmrpb
Some Pictures:
PsyBorg
Wake up! Time to fly!
Thats not a plane thats an airborne drill bit :p you have that set up nice. It looks seriously agile and locked in. I would LOVE to be in FPV for a ride in that to see what that kind of agility looks like.
jmrpb
Thanks!
It really likes to make fast rolls. The hard thing to do is to fly level and straight :)
Cheers,
Bernardo
jmrpb
... And it is small enough, so you can take it in your car for that evening flight during the holiday season!
Happy flights and happy landings,
Bernardo
