Cosmocop - you almost got a set of plans today......The battery came loose and slid back a half inch. Was Mr. Toad’s wild ride all the way to the ground. I think I’ll install the small foam back stop that I kept saying I was going to glue in
Zephyr - the 64mm EDF version maidened today. Lessons learned:
1) By moving the fan forward into the wing and moving the battery aft to balance it the aircraft need far less tail down force to achieve level flight. I launched it with the same tail trim and CG location as the V1 50mm and it pitched up violently and required 50% nose down trim to maintain level flight. Once trimmed it tracked like an arrow. Now it requires very little back pressure to maintain altitude in turns and is much more responsive in pitch than the V1 theoretically this change alone should increase the top speed due to reduction of trim drag. Aileron effectiveness remains the same (which is awesome!), I think moving to a fully flat bottomed airfoil was a good call.
2) Glueing two small strips of 120 Grit sand paper to the lower fuse makes gripping it for hand launch much easier.
3) The split flap design, whilst not scale, is UNBELIEVABLY effective!!! At 60 degrees deflection it requires less nose down trim than V1 with it’s plain flap design at 40 degrees and produces a ton of drag. It needs about 25% throttle in the glide and when you want to land you just chop power and hold the nose up - it literally just sits down.
Love this airplane, Mate! Now it’s time to build the turtle deck and give her a coat of paint!
cheers,
Mac.
