Mighty Mini Arrow Oscillations
jbeckwit
Greetings - just flew my Arrow and at higher speeds I get vertical oscillations. Seems unrelated to throttle position - only speed - high throttle level or climb - or low throttle but descent. Using a Spektrum AR630 receiver and NX8+ Tx. with and without Safe - but AS3X on. Any ideas, thoughts?? TIA
It has to do with the AS3X, it's over-correcting.
jbeckwit
My suspicion as well - but I'm just using the default settings. I'll tone it down and see if that helps. Kinda fun to watch though (just not a good idea....). Thanks
Are you talking about that when you get up to higher speeds your air frame starts bouncing?
How do your throws look at full rates . If the control surfaces move too much/far, that causes the controls to be super reactive, and the AS3X will have a tendency to overcorrect as well. Is there a way to disable the AS3X with a switch and see if it changes with it turned off? Is it possible to set the AS3X gain with a potentiometer while in flight? You may be able to fine tune the gain if so.
It's possible that your airframe is bending at speed/load.
jbeckwit
Litterbug - all good answers - much appreciated. I'll check 'em out. On the variable AS3X - that's a possibility, but will be new territory for me. I've never used that variable knob for anything - a good time to try it. Thanks!!
Be sure there is no slop/play/slack or flex between the servo, pushrod and control horns. It can sometimes cause that. If it persists you can try reducing the AS3X gains.
Thanks - good ideas. And working the gains idea.
jbeckwit
I have that problem too! I thought it was my gyro make getting a little shook up! lol
Pretty good bet it’s the AS3X overreacting - at least in my case. I’m using the default settings, but I can turn them down so, we’ll see. Again, I’m using a Spektrum AR630 with a NX8+ Tx.
Foamforce
The fastest way to confirm is to fly it and turn off AS3X. If the oscillation goes away, that’s what it was.
On my cheap gyros, I can set the gyro master gain with a knob on my Tx and tune it mid-flight. I would imagine you can do the same with yours.
jbeckwit
jbeckwit
Thanks - that’s pretty much my plan. I do have a control knob on my NX8+ I can use - but have never done that before - good time to learn….:)
I can't change the settings on my gyro so I might just put the control rod further in on the servo arm, it's all the way out right now.
