Mighty Mini Master Series Spitfire
Grifflyer
WWII fanatic
Thanks, was thinking about coming up with actual plans for the micro DH.88 I just built and I wanted to shoot for something in between micro and mini lol. The 24" wings and 70 gram air frame (100gram gross) are cool but a royal PITA to get put together!
That would be really cool!!
jfaleo1
Yeah you could use that motor, just use whatever prop the manufacturer recommends. I fly with a 6x4 prop I might need to prop down come summer time because the ESC doesn't get any airflow.
I was thinking a desert air filter scoop an punch a hole for airflow, or make the radiator “functional” by opening up the front part say and pushing air into the wing and up into the fuselage. Either of theses require an opening in the back of the wing somewhere but a long look at one of my books should yield a honing place for an outlet😁
Grifflyer
WWII fanatic
Yeah, you could try something like the hood scoop on the mk V spit...
IcedStorm777
So how would i change the file from a PDF to a DXE while also being able to move stuff around? I am only using the laser cutter to cut the pieces out and not to do bevels. The reason i need to move stuff around is because the laser cutter only has an 18x24" build area. Thanks!
buzzbomb
I know nothing!
You can import a pdf into Inkscape, ungroup it and move stuff around, then export as a dxf.
Grifflyer
WWII fanatic
Lucky for you @GremlinRC has already converted the plans to a Dxf file, you might have to move some things around to get it to fit in the 18x24 build area, but it should give you a good starting point.
GremlinRC
FT_Nut
DXF files are attached. Thanks GriffFlyer for producing such a fine set of plans and allowing these dxfs to be shared. I've joined the smaller polylines to make continuous polys for cutting and removed the extraneous stuff like text. Where parts require more than one copy, I've duplicated them as required. So really nothing to do but arrange the parts as required and apply the required machining op and output to gcode. I can't wait for the weekend to get cracking on this build. Planning to print your 3D printed parts too GriffFlyer.
  • Mini_Spit_GriffFlyer_DXF.zip
Grifflyer
WWII fanatic
Those look awesome!! Thanks so much for doing this, I'm going to add them to the first post when I get the chance.
CrazyFastFlying
They've been added! I uploaded them to google drive so I can share them through an article whenever I get around to writing it...
I'm planning to build your spitfire sometime soon, Grifflyer.
GremlinRC mentioned something about 3D printed parts, can I have the files?
chris398mx
Thanks for the dxf files.......if I ever get time to put together my TimSaver CNC, I will build this plane
Grifflyer
WWII fanatic
two questions
302 grams is the weight of the entire plane without electronics?
I'm afraid of the European foamboard
Would you have to change something to cover it with 3mm foamboard instead of 5mm?
302 grams when it's all ready to fly. You don't have to worry about changing anything, the skins will end up being a little bit too long but you could always trim them after you test fit them onto the fuselage frame. The hatch will end up being 4mm to wide, but again you can just trim it to fit.
GremlinRC
FT_Nut
Build started. I have to say, this is by far one of the nicest and well thought out plans that I have ever built. If anyone is mulling it over, just do it, you won't be sorry. I'll post some pics as progress continues. Thanks again Grifflyer for this really great plan.
Grifflyer
WWII fanatic
Thank you for the kind words!! Good luck with your build, I look forward to seeing your progress pictures!!
GremlinRC
FT_Nut
I finally got around to making some progress on this. Due to 6 weeks of incessant wind here in Ireland, there has been no opportunity to do any flying so lots of building projects are on the go.
You might notice the first mistake. The elevator control rod on the underside of the H stab. However as you will see, I worked around that well enough.
A bit of judicious trimming and it was all good.
All together and plenty of light filler in the gaps.
Masking really is a test of patience!
But its worth it.
Decal application started.
Underside with Grifflyers 3d printed parts.
Just as an aside I have another of Grifflyers excellent plans on the bench!
Might be a while before I get to maiden any of these, It's just storm after storm here at the moment.
