Mighty Mini Master Series Spitfire
Aviator08
Flagstaff,AZ
Well.... I tried to use ink jet stick on film..... only problem is that it doesn’t print the white. :rolleyes:
Sherman
I love the look of this little spity. I'm wanting to build but don't have the tools to do a full-size print and don't know how to make tiled plans. Does anyone have the plans tiled on a page I might have missed?
Grifflyer
WWII fanatic
Thanks!
You can print the full size plans on regular sheets of paper if you use Adobe Reader. All you have to do is open up the plans in Adobe Reader and select print. After the print window opens up there should be a section in the middle of the window labeled "Page Sizing & Handling" right below that there should be options to choose between "Size" "Poster" "Multiple" and "Booklet" You are going to want to select the "Poster" option. Next, ensure your tile scale is set to 100%, your overlap is set at 0.005 in. and that you have the "Tile only large pages" option selected. You can also select "Cut marks" which will make taping the sheets of paper together easier, but it will increase your page count from 8 to 12. Lastly, go down to the bottom of the print window and click print.
Note: If you do not have the poster option on your laptop you may need to upgrade to the latest version of Adobe Reader. It may even be old enough that looking in the program options for updates does not work. You will have to go to Adobe website to get new version.
sh0sey
I’ve had parts cut out for a while now, and finally getting around to assembly! Loving how it is going together too. Really great job! Hopefully can find some time this weekend to finish her up.
