Wingeddrac0
Hello all,
I've only recently ccme back to rc flying and I'm having a lovely time scrap building the mini scout and mini mustang. However I'm having trouble picking the right electronics for the planes. My plan is to power both aircraft with the same mini power pod. I dont have acces to dtfb or adams so im stuck with westfoam which is a tad heavier. Therefor I'd like to pick out a motor thats close to the F pack motor, but I'm lost in all the different types of motors.
I've done a bit of research and the initial numbers on a motor describe the diameter and height(coils) of the motor, those have big influences in performance.
kv is rotatins per volt (sorta) and bigger kv's means smaller props which will swing faster and have more trust.
I'm quite happy with HK so if possible i'd like to order from them.
So my question is as follows, which motor is close to the F pack motor?
I picked a few choices that I felt were similar but I'd like someone to shed some light on them and explain why it'd be a good or a bad pick.
https://hobbyking.com/en_us/m2205l-brushless-motor-for-rc-model-aircraft-ccw.html?wrh_pdp=1
https://hobbyking.com/en_us/qav-rt2204-2300kv-quad-racing-motor-ccw.html
https://hobbyking.com/en_us/brushless-motor-c2206-2300kv-ccw.html
Also, servo control rods, which diameter is mostly used for 5g/9g servo's? I've heard Josh talk about 1mm rods in one of his build videos, is that a standard diameter for rods?
Thanks in advance!
Thanks in advance!
