Mighty Mini P-51B Mustang
Mighty Mini P-51B Mustang 1.0
Please log in to download
Grifflyer
WWII fanatic
Grifflyer submitted a new resource:
Mighty Mini P-51B Mustang - Fuselage mod to change the Mini Mustang from a D model to a B model
If you're anything like me then you'll like the looks of planes better when they have a razorback. While I like the look of the bubble canopy on the P-51, I prefer the looks of the P-51B which has a razorback style canopy.
I reconstructed the fuselage of the FT Mini Mustang so that it looks like a P-51B mustang, both Mustangs use the same wing. I did lower the wing cutout so that it lies flush with the bottom of the fuse to give you more area to hold your...
Read more about this resource...
MiniacRC
Your welcome, how's the 190 coming along?
The 190 is kind of stagnating since I was a little tired mentally after finals ended. But I'm going to be doing the build video voice over soon and wrapping up release hopefully.
A little question on your stang. Is there any reason you chose to detach the belly/radiator from the fuselage pieces as they were originally? I'd think you would be able to slide the wing through just like on the OG stang when building. But I don't want to try it if it failed for you. Thanks :) 77367970_1350017651837894_7341115246586626048_n.jpg 72130238_1309352082571118_2212037543329792000_n.jpg 75439385_1346332268873099_3801433505959772160_n.jpg
Grifflyer
WWII fanatic
A little question on your stang. Is there any reason you chose to detach the belly/radiator from the fuselage pieces as they were originally? I'd think you would be able to slide the wing through just like on the OG stang when building. But I don't want to try it if it failed for you. Thanks :) View attachment 152885 View attachment 152886 View attachment 152887
Nice!! I left the radiator detached because I couldn't slide the wing in without the radiator creasing, and because it would be easier to glue in the wing without trying to manuever it around something.
