I am all out of foam. Free shipping happens at $100 so I need to come up with a component that is usable at any stage. Looks like there's a halfway decent battery charger on sale...
Wrong thread, but hey its the right plane. I got piano wire, and plastic guides. Servos are on the way. I haven't close up the back of the wing so I can sneak the wiring in later.
If you build with the Brown FT foam board or waterproof whatever foam board you do use, then yes it is designed to fly from the water. If you just use regular untreated foamboard, your plane will be soggy and you will be sad
And a bit more. Nose, hatch, wing tower and stab servos in.
Not going to use much, if any, poster board. Just need to trim the skins and sand a bit more.
