Man, that bug I had wiped me out. Been trying to catch up with work (farming just got crazy again), so I haven't had much time for building. I did redesign the tailfeathers when I was sick as the old design was hard to fit together straight. In order to keep it scale I split the vertical stab into two pieces, and I'm doing a split elevator the same way as my previous A6M Zero design. The redesign should keep the build simpler to get square even if there's a bit more pieces to glue.
Here's the split elevator. I use a bit of piano wire bent like so:
Press down on it gently to make an indentation for cutting. You'll notice one side is offset. That's to leave room for the servo horn.
Cut along the indentation then use the wire to make a groove:
The wire should fit in like so. You want the wire to be all the way back against the hinge line.
Take a BBQ Skewer and make an indentation in the foam on both sides of the wire. I only show one side here.
Make sure the elevator moves freely. If the wire hits foam anywhere and stops travel, just compress the foam with a bbq skewer. One it moves freely you can cover up the gap between elevators with a piece of posterboard and tape.
Cut out your vertical stabilizer and make your bevels.
Glue the bottom portion to the horizontal stabilizer. Make sure it's 90 degrees. It will fit together with slots, so that helps with alignment.
Next glue on the top portion. It also has an alignment slot.
Next I add a drop of glue so that the rudder becomes one piece. I also make a groove with a bbq skewer/toothpick.
Glue a piece of bbq skewer/toothpick into the back of the rudder. This keeps things very strong.
Forgot to take a picture, but there are two side/reinforcement pieces that get glued onto the vertical stabilizer. After you glue those on, the whole thing fits into the slots on the fuse where it can be glued into place.
I also glued the wing tower into place. Unfortunately I made the measurements while feverish and have discovered it needs to move back some. I'll be cutting it off and making another tower.
I'm hoping to make and install another tower tomorrow then I can start working on posterboard for the top deck.
