I think you did well on your build, although cardboard is not used much.. it showed the idea is practical and looks good..
esc's ...most have a bec circuit. its normally only the bigger stuff that has an option to go without a bec, as big planes have their special power requirements ..
Motors .. normally come with a prop adapter and a mount.. no bolts.. sometimes they have small bullets soldered on, sometimes you have to do it yourself..
On this size of model, I fit my motor using 1/2" long self tapping screws . these go into a 1/16 ply plate.. I screw on the mount, then remove it again.. the screw holes are given a drop of CA to make them tough.. once set ,the mount is fitted back on and the ply is glued to a nose block made from EPP... EPP works well because its got give, so in an impact it doesn't snap like depron will..
Props and adapters , its rare that the prop will fit easily, but they mostly now come with a series of rings to help... on mine I have to fit a ring, then drill it out a touch to get a good tight fit.. then balance the prop..
loose fits are no good because the prop will always vibrate, being fitted off center its going to be out of balance..
The wing warp was ironed out and the gear all fitted... I havnt added the ailerons yet.. Its going to fly first on the two channels like their other minis... but the rest is done.. using all hobbyking items ... 2211-1700 motor .. 4ch orange mini RX.. turnigy 1440 servos 4.4gms ..and a 500 2s for power..8x4.3gws prop
AUW is 6.1oz... on a 1sqft wing.... so first thoughts are that this will be a bit fast for indoor use, but it will get a go tonight..
with the wing section and being all open under the fuz it may be draggy enough to fly slower..
the motor has a few degrees of down and right thrust..
All Up Weight with the covered depron build ....with no battery 140gms....
the other flite test minis are 115gms....
most of my indoor models tend to be nearer the 200+"sq size and so have lower wing loadings on very similar weights , lower loadings flying slower, are just about correct for a hall....
I could have saved weight by not covering the depron with laminating film, but I am trialing this material at the moment.. I could have also stayed away from the hot melt adhesive, its another weight adder
Its got plenty of power, enough for vertical, so it should fly, but perhaps too fast...
the servos are glued in under the cockpit area, laying on their sides with their arms vertical.. the battery has to go as far forward as possible for the COG which is on the fold...
