Mighty Mini Vampire (Fighter Jet)
JamesWhom
Project Air on YouTube
Introduction:
Cheers for checking out this post! This forum thread is dedicated to my Mighty Mini styled deHaviland Vampire design that you can build yourself. It's small, quick to build and only uses 1 sheet of foamboard.
FREE PLANS
https://drive.google.com/drive/folders/1r94efzJRkwjw9tPLo3BF4oyK1GnqiaFc
Note: These plans are still undergoing some work so you may find a few things a little off.
SPEC
- Standard pusher race quad motor power such as a 2205 (with possibility to mod with 50mm ducted fan)
- 2s-4s battery
- 3ch (bank and yank)
- 24" wingspan
- 1x sheet of foam board to build
- 6-7 foam board pieces to cut out and glue
- 100mph+ with 4s
PREVIOUS VERSION HISTORY
V0.1
- Large 1000mm version (Summer 2014). Link to Article: https://www.flitetest.com/articles/whomz-vampire-free-plans
V0.2 - Large 1000mm non-scale sport version for max speed.
V1.0 - Mini 610mm version (Winter 2017). Link to article: https://www.flitetest.com/articles/mighty-mini-vampire-free-plans
V1.1 - Updated mini version for better performance and durability (Early 2019).
JamesWhom
Sorry for the terrible photo quality. First steps - a mock up glider in process just to see if the CG, lift and general dimentions work in the real world. Going to finish it and then use it as a chuck glider.
Exciting times!
Oh and here is an old video of the last Vampire to get you pumped. Yeah!
JamesWhom
I'm in! Are you planning to be able to convert this to an EDF or strictly pusher?
I've never worked with EDF's this small before so nope, probably not right now. Maybe at some point in the future though. I've actually only used one EDF before and that was on a boat :p
Progress tonight has been good but the forum won't let me upload my pics! Grrr.
foamtest
Toothpick glider kid
I wish I could build one right now, but I haven't had much time to build lately, but this is definitely going on my long list of things to build.
foamtest
I would love to build one but I can't at the moment, it will definitely be added to my long list of things to build.
JamesWhom
Fuselage pod coming along:
Underside showing exposed electronics and the battery bay up front. Going to put a hatch on the underside of the battery compartment as the way you access the battery. My old bigger Vampire had a slide out, very long powerpod that housed the battery up front, but this was super impractical.
Aaaand a couple of wings ready for folding. Going to have a unique spar setup going on, but more of that later. :)
JamesWhom
Well, hopefully I make it simple enough to put together that it ends up being a must to build it right away ;) It's going to only take 1 sheet of DTFB too. Yay!
foamtest
Also something I just noticed with your build, can these wires withstand the current your motor is pulling? They look really small even for something like this.
Or it could just be the thicker wires fooling my eyes, I'm not entirely sure, but I also don't want this to end up in a flaming ball of fire despite how cool it would be.
jpot1
Definitely interested. Looking like no room for the mini power pod? I’m guessing the wing will slot through the motor pod?
JamesWhom
It's been fine in other projects, but I know what you mean. Thanks for the concern :)
JamesWhom
Okay so here is Prototype 1 which hasn't been flown yet. Needs pushrods still installing before then. There are some things I'll be changing on the plans. One is the gap between the top of the wing and the fuselage slot. It's slightly too big. I might also make the vertical stabilisors a little smaller and more scale if it can handle it. I purposely made them slightly larger on this one to compensate.
It builds pretty fast and seems to tick the box for simplicity even as a twin boom design. The strength of the booms come from BBQ skewers infused into the foam.
It should be pretty quick and lots of fun!
JamesWhom
Just did the maiden and - OMG. This thing rocks! It's such a blast to fly!
I walked down to the field at the bottom of the garden and did a couple of glide tests. All seemed to work pleasingly. It was getting dark with the last of the yellow clouds illuminating the sky, but I decided that there was still enough light. The thing rocketed out of my hand and almost disapeared over the tops of the trees that line the small flying area. I pulled up and watched the little jet power upwards. It tracked perfectly. After a few circuits, I had about four or five attempts at landing it. Eventually it was down. No damage. Success!
Some observations:
- Needs a little more elevator authority on landing to flair. Rates can be set for less authority when in normal flight
- Capable of at least 70-80mph with a 3s.
- Tracks perfectly
- CG spot on
- Very little trimming needed
Right then! On to some slight alterations!
Grifflyer
WWII fanatic
Some observations:
- Tracks perfectly
- CG spot on
Sweet! can't wait to try it on 4s and, did you get a video?
