Mini Aeromaster (Like) Biplane
Michael9865
Mini Aeromaster Inspired Biplane
I have been a fan of Lou Andrews Aeromaster since I was a teen, circa late 1970s and early 1980s. Mine was built for me by my father, that was a great gift. It flew one with a Fox Eagle III on the nose. Now since I returned to RC flying a few years ago I just had to make a biplane with similar lines.
I took a FT Mini Scout and made it into a biplane a few years back, http://forum.flitetest.com/showthread.php?20816-Mini-Scout-Biplane-With-Plans , after tweaking the design a little I published the plans. This biplane is the next step to get closer to the big biplane of my youth. If this biplane is as successful as I hope, I will then size it up to 32" or so.
This is not going to be a fast build. (Then again it just kept calling me to finish it.) LOL! I am still working on the Miles Sparrowhawk for FF2017 in Ohio.
Also after this Mini version is perfected I will share the plans. This biplane will be built mainly with 2 sheets of DTF, tape, white gorilla glue and some hot glue. Hopefully you will enjoy the journey.
I suggest using the forward CG marks on the top wing for your initial flights.
Proof of Flight video.
https://youtu.be/6npT_xwsHxM
Updated Beta Plans
See attachments
Change .zip to .dxf
View attachment Mini Scout Bipe III Page 1 Beta V1.1.zip
Change .zip to .dxf
  • Mini Scout Bipe III Page 1 Beta V1.1.pdf
  • Mini Scout Bipe III Page 2 Beta V1.1.pdf
Michael9865
Top Wing
Top Wing
Top left wing and spar cutout
Top right wing and Spar cutout
Top wing spars folded and glued
Top wing Sharpie work done, the dots on the bottom surface of the wing is the CG mark.
Getting the fold practiced after beveling, the dot on the bottom surface of the wing is the CG mark.
Transferring the spar location from the top of the wing to the bottom. This was not a good move. It caused the spar to not be in the correct location. You will see on the lower wing I glued the spar to the top of the wing to ensure that it is in the correct location.
06 Tranfering The Spar Location From The Top Wing To the Bottom Feb 03, 12 15 15 PM.jpg
Top wing spar prepared to glue in (in the wrong place, doh)
Top wing spars glued in place (**Should be glued to upper part of the wing skin first.**)
Picture of completed top wing
Michael9865
Bottom Wing
Laying out the checkerboard pattern on lower wing
09 Laying Out The Checkerboard Pattern on Lower Wing Feb 23, 11 03 00 AM.jpg
Sharpie work done on the checkerboard pattern on lower wing. I like the finished product, but wow that is a lot of work. LOL
10 Sharpie Checkboard Pattern Completed on Lower Wing Feb 23, 11 50 30 AM.jpg
Setting up the spars on the lower wing after beveling the leading edge and running a skewer down the the fold areas on the bottom wing. I did glue the spars the same way I did on the top wing spars.
11 Lower Wing Beveled and Releaved with Spars Attached Mar 09, 8 52 30 PM.jpg
Gluing the airfoil into the bottom wing. I used a dolop of hot glue at the outer and inner edges to keep the trailing edge of the bottom plate in the correct location while the white gorilla glue dried. Don't tell my college Psych and Sociology profs that I re-purposed my textbooks. LOL
Gluing in the dihedral, the top wing has none. The Psych and Sociology textbooks are heavy, no worries on anything moving.
Bottom wing completed with 1 5/8" dihedral under one wing tip.
Michael9865
Fuselage
Fuselage Build
Parts laid out to start the fuselage, I realized that I forgot to have my cnc cut the score cut at the fuselage side bend near the rear of the bottom wing. I have went in to update the beta plans.
Fuselage parts with extra foam peeled away. The extra paper on the lower section of the nose will be folded over to strengthen the edges.
Fuselage sides and top glued with white gorilla glue and tact in place with hot glue at front, bend, and rear utilizing a "B" fold. Weighted down the assembly while the glue dries. The bottom plate of the fuselage is just sitting on the body as a spacer. It is easier to install the equipment/electronics before gluing the section under the bottom wing in place.
Nose detail of the paper having been folded over to strengthen the edges. After the white gorilla glue dries I will trim the excess away. I used hot glue to accomplish that.
Lower rear section of the fuselage glued in place
19 Lower rear section of the fuselage glued in place Mar 11, 11 25 37 AM.jpg
Removed the area where the lower wing will attach
Detailed look inside at the area I removed the foam from the bottom of the fuselage. I adjusted the beta plans to move the wing up 2mm. I also adjusted the center support and the wing struts accordingly.
24A Detailed look iside at the area I removed the foam Mar 11, 3 24 46 PM.jpg
Started work on the power pod, folded up and gluing up the foam section of the power pod. I used white gorilla glue on the bottom outboard edge and hot glue on the edge of the side piece.
Showing detail of the A fold
After gluing on firewall the taping begins
More tape reinforcing applied
I use a C-clamp to ensure the firewall remains seated to the foam
23 Using a C-clamp to ensure the firewall remains seated to the foam Mar 11, 3 08 19 PM.jpg
I test fitted the old pod from my Mini-Scout Biplane and realized that I put the skewer holes a little high. So I went in and lowered them on the Beta plans. I also realized that I have the openings for the rudder and elevator push rods in the wrong places. So I corrected their locations on the Beta plans.
Attached the A2204-14 1400KV Brushless Motor that I used on my Mini-Scout Biplane. It will be spinning a 7X6 prop.
Wing section build to correct the opening of the fuselage, corrected the beta plans
Bottom wing installed
Rough sketch of landing gear
Landing gear installed
Installation of front former also glue down thrust piece in place
38 Installation of front former also glue down thrust piece in place Mar 17, 11 57 04 AM.jpg
Detail of down thrust piece
Upper formers glued into place
Beginning to install the poster board upper fuselage
42 Begining to install the posterboard upper fuselage Mar 17, 11 28 56 PM.jpg
Poster board installed
Poster board installed front detail
Installed the center support for the top wing
Installing outer wing struts. I should not have installed at 90 degrees since the bottom wing has dihedral. I have updated the beta plans.
Attached top wing
Michael9865
Tail Feathers and Misc Work Progress
Sharpie work completed on the tail surfaces
Hinge work completed on the tail surfaces. Notice the 45 was cut into the horizontal stab and also on the rudder.
Attaching the horizontal stab to the fuselage
Michael9865
Electronics installation
Installed servos rudder to the rear and lower elevator forward and higher
33 Installd servos Rudder to the rear and lower elevator forward and higher Mar 17, 12 00 38 PM.jpg
Elevator and rudder servo install front view
Imobilized the control surfaces and installed control horns and tail skid
36 Imobilized the control surfaces and installed control horns and tail skid Mar 16, 8 17 12 PM.jpg
Control rods connected
Aileron servo installation
Michael9865
I got a lot done on the fuselage and motor mount. I have been working on this biplane while I watch NCAA basketball conference championships.
PsyBorg
Wake up! Time to fly!
And this years winner for best use of a psych degree in the aeronautics sector goes to.....
This is progressing nicely. It will also look cool with the art work you have done already.
Michael9865
After attaching the lower wing it struck me that this would look good as a single wing. Hmm, shorten the nose a little. maybe make the fuselage about 8 or so mm wider.
I don't need to go down this rabbit trail until next winter. LOL
JimCR120
Got Lobstah?
Site Moderator
As I was preparing to mention about that I continued to scroll down. I stuck my nose in one of those books once, not likely gonna happen again. Use it to hold things in place while glue dries, finally useful information. I wonder what that means about my inner self... no I don't.
Michael9865
Ready and waiting for flying weather
Updated posts 4 and 6. I could not stay away from working on this plane.
314 Grams without wheels
Top view
Right front quarter view
Right rear quarter view
Bottom view
Michael9865
It Flies! Ronnie Timmerman took it off for the maiden for me, I then finished out the flight. I am happy with how it flies, it is a tad under powered. Joel Cannon of Flite Test Community Podcast tried it with a Blue Wonder, 12A ESC, and a 2S 800MAH on it. He recommended a 2205 Red Bottom, but I don't have one. He offered to try the Beta plans with his Red Bottom motor. Tomorrow I hope to test out a GT2204 KV2300. I can almost hear Tim Allen grunting and telling 20A ESC and a 3S 1000MAH would help also. LOL
I will link the proof of flight as soon as it finishes uploading.
Michael9865
Beta Plans Release
Here are the Beta plans. If you build from them please let me know if you find any errors or suggestions to make it better. Thank You!
View attachment Mini Scout Bipe III Page 1 Beta.pdf
View attachment Mini Scout Bipe III Page 2 Beta.pdf
Change .zip to .dxf
View attachment Mini Scout Bipe III Page 2 Beta.zip
Change .zip to .dxf
View attachment Mini Scout Bipe III Page 1 Beta.zip
I also did not get the chance to try a different motor yet. I may just order a 2205 or 2206 red bottom.
Michael9865
Fidget
This is great! Thanks for sharing.
It's fun to see what people use for weights too. I hadn't seen one of those little fruit punch barrels in a long time.
