Resource icon
Mini BF 109 (SFRC) Plans - FULL-SIZE v1.1
AIRFORGE
Make It Fly!
SFRC_2088
No problem! Great original plans!
I'm thinking about building one at 200%, too. 😲
Should be very cool!
One thing I did see which isnt a huge deal, I noticed on your updated plans you have all three wing spars as plywood. Im sure that would work, the way I designed it was to be both larger spars made of foam and the smaller one made of plywood or 3d print. I then stacked them in this order: foam, foam, plywood.
Im sure all plywood would work, and maybe even be stronger, I just kept the spar pretty thick to make the airfoil easier to form.
AIRFORGE
Make It Fly!
Crud. I didn't realize that. I will make an update. Wow, thanks! (EDIT: UPDATED)
