mini firewall
Arcfyre
I run into that same issue with the mini pods. I've pretty much given up trying to route the wires through the firewall. As the power pod is open on the top, I just run the wires over the firewall and into the pod on the open side. Not gorgeous, but it works.
#3
Good info thanks, on the scout there is not much room there either, even then it feels like I need to bend in the middle of the shrink, just wondering if those wires / connections can tolerate much manipulation.
buzzbomb
I know nothing!
#4
They will to a point. I usually go for a happy medium and widen the hole just enough to get the wires to go through without ripping them out of the solder. A little slice with a hobby knife along the grain at the bottom of the hole, a little clip with some wire cutters along the side of the hole, and done.
buzzbomb
I know nothing!
#8
Thanks for your help, was not sure if I was making something out of nothing, but I see you have dealt with this issue and not just forced a 90 bend in the harness which is what I was tempted to do.
I've done that too. Lots. The motor sits flush to the firewall and wires have to get through it. We alleviate the stress on the wires, when possible. Sometimes it's just fold the suckers over and push them through. :)
FDS
I run 30A esc’s in everything. I just buy in bulk, we can’t get small sized fixed wing ESC’s here so the difference between 20 and 30a ones in size is nil. I always want at least 5A headroom.
Its no problem when the battery goes under the power pod, I haven’t had any balance issues.
BATTLEAXE
Your right thrust angle is perfect, better have more then not enough. If you decide to go up to the F pack on the Mini Scout like I did it will be just fine... and the F pack has a 20 amp ESC and the fit and balance was on point.
The Hangar
Fly harder!
I second this - I had the same experience.
