jsportser
Here are some plans for a mini Bf-109. The plans aren't pretty, but, feel free to give it a whack. Here are some things you need to know to build it. For the top hatch peel the paper off the bottom side to help it bend. Then for the power pod just sink it in until the motor doesn't show, and then put some BBQ skewers through it to hold it in place. Also 0 thrust angle, at least for the 1306 motor. Now for the poster board you'll have to mess around with it a little bit to see how it fit's. If I try to explain it, it will probably just confuse things. Then do a "B" fold on the fuse and everything should be good! Hopefully you enjoy it, and... HAPPY FLYING!
