How much dihedral are you suggesting?
Are the plans in post #1 the latest rendition with everything updated?
Thank you.
Hey ACE62! If I remember correctly, the wing is built the same way as the original FT Flyer, so you use the power pod as a dihedral gauge. I think you should be able to put it together by watching
the build video of the original FT Flyer and doing a little educated guess work to make the mini power pod. As
@AIRFORGE pointed out, the plans in post 1 are not the most recent version. I'm surprised and honored that someone is interested in building this after all these years, so I'd be happy to help out with any problems you run into!
Also, Flite Test changed the FT Flyer since I made V1.8 to run off of an A pack when they made the
Fun Pack, so you might want to check that out if you're looking for a simple, floaty build with this power pack. My rendition of the Flyer has less wing area and I moved the CG back a bit, so it's a bit faster and more squirrelly. You could tone it down by reducing the elevator and aileron throws though.
Good luck with your build!
