Garret234
I just finished shrinking the ft spitfire to 65%. The build went very good with some minor changes.
Here are some pics[/ATTACH]
The wing span is 25", The auw is 7.0 oz, and dry weight is 5.3 oz. You can see the size difference between the normal sized one and the mini.
To save weight I didn't do a folded wing just a simple undercamber. The plane is only elevator, rudder,and throttle. Do you think this will be enough to fly this? I added the dihedral just like the big spitfire. For electronics I used a 1806 2300kv, a 10 amp DYS ESC, a 6x3 prop, a 500mah 3s,and 7.5 gram servos. This was the smallest servo I had at the time. I might post a video of the maid in if it will just stop raining here in Oregon.
Thanks for looking!
Thanks for looking!
