Mini FW-190D
Grifflyer
WWII fanatic
It flew!!
I love the way it flies and how it carries its momentum, and you can see early on in the video when I went up to do some stall tests it didn't tip stall it just fell straight down. Then at the end when I tried to land it took me three times to try and get it slow enough to land I think that happens because I'm use to flying FT style foamies which have quite a bit of drag.
Namactual
Wow!
Great job on this Griff! What a beautiful bird. It looks she flies as good as she looks too.
Great work man.(y)
rockyboy
Skill Collector
That looks like a great flyer! Could hardly even tell the prop isn't black till it landed :p
Congrats!!
wilmracer
I build things that fly (sometimes)
Congrats!!
Just hit it with a sharpie! I do do that on APC props and it works well. Not sure if you could get away with doing the yellow tips on a blue prop, but I bet the black would be fine. Its MUCH quicker than painting and rebalancing
Looks awesome and flies great. Nice work!
Grifflyer
WWII fanatic
Good idea I'm going to try that:D
PsyBorg
Wake up! Time to fly!
Wow how the heck did I miss this entire thread?
What an amazing job you did. This should get a feature spot for an interview at Flite Fest if you go. We should poke Stefan with a stick til he spotlights Griff and the amazing things he is producing at such a young age. Could easily be the next Andres.
Grifflyer
WWII fanatic
Wow thanks for all the kind words, sadly I don't think I'll be able to make it to Flite Fest.
But the community should also be spotlighted. I only knew how to build the plane because of all the threads that other people have created that I was then able to read, and then learn how to be able to build a plane using all the techniques, that were involved in the build.
FOGeologist
How did you make your fuselage sections? Did you use plans that cut them into slices? Did this involve some sort of software?
Grifflyer
WWII fanatic
OK, so what I did was a I took this image,
Blew it up, so that the dimensions on paper were what I wanted in real life printed and taped it all together, Then I cut out each individual former glued them to pieces of cardstock until they were about 1mm thick and then I tacked them to pieces of foam and cut them out and glued them together side by side:)
Are you planning on making a similar model?
FOGeologist
OK, so what I did was a I took this image, View attachment 108510
I may use this approach to make formers for... some kind of a warbird. Probably a spitfire. I am examining plans from a wooden kit that may guide my approach. Thinking about making this ship, but not using balsa.
  • spit.dxf
  • spitmk9.pdf
Grifflyer
WWII fanatic
Oh COOL! make sure you make a thread about it if you do try and make one;)
bracesport
In my experience, using hand laid fibreglass was a piece of cake, you use very little epoxy, and with a mini paint roller it goes on smoothly! I used Wests 105 epoxy and only bought 500mls (a small bottle) and still have heaps left.
Grifflyer
WWII fanatic
Cool I'll definitely remember that, on this build I was trying out hot wire cutting for the first time and I didn't want to spend a lot money and time, but the next time I do a build like this I'll definitely use fiberglass!!
