i won a motor,props, esc, prop saver off ebay for cheap money 3.50 ship to my door.
i too am confused when it comes to motors.. but your explanation helps a lot Harley.
i figure i could pick up 2 more of these for stupid money and build a really cheap tri-copter.
the specs on the motor are:
Specification Motor:
Name : A2212-KV1000 Brushless Outrunner Motor .
Motor for small fixed-wing , helicopter , Multi-axis aircraft .
Motor for ESC 20A - 30A .
Motor for 8045 , 9045 , 1045 propeller .
RC Pull weight : 300g - 900g .
Note : RC Pull weight Different , Optional ESC and propeller Different .
Internal Resistance : 230m¦¸ .
No load current / 10V : 0.4A .
Number of battery(Ni-MH) : 6-10 Ni-MH/ 2-3 Li-Po .
Current capacity : 12A / 60s .
Max efficiency : 80% .
Size : ¡é27.8 x 40 mm .
weight : 47g .
ESC
Name:HobbyFans 30A ESC
Output: Continuous 30A, Burst 40A up to 10 Secs.
Input Voltage: 2-3 cells lithium battery or 5-8 cells NiCd/NIMh battery.
BEC: 2A / 5V (Linear mode).
Max Speed: 210,000rpm for 2 Poles Outrunner BrushLess Motor, 70,000rpm for 6 poles Outrunner BrushLess Motor,35,000rpm for 12 poles Outrunner BrushLess Motor
Size: 51mm (L) * 25mm (W) * 8mm (H).
Weight: 25g.
it came with 4 props two 8", one 9", and a 10".
if i was to bid on 2 more of these ESC/motor deals.. would this make a slow flying tri-copter?
or should i just save this motor/prop for a foam plane..
that was my original plan, figured one of the FT plans would work with it if i won, which i did not think i would at that price.. and for the price what teh heck.. i figured the props alone were bidding. the price i won, seems to be the norm for this package. so for pennies i could get a power plant for a tri copter.
