So I've got 8 flights on her and I show up at the field at 6:30 in the morning. Sun is shining, no wind, blue skies - just beautiful. The Tele takes off great, and I'm doing some lazy circles and loops for a few minutes and I think "there's no wind and no witnesses - let's practice some inverted flight so I can get ready for the club class pattern contest I want to do this fall".
I start about 1 mistake high pointing to the west and pull a loop to get into an inverted attitude. It takes me a moment to get enough push on the elevator to stabilize into inverted flight pointing east. Instead of 2 mistakes high where the loop left me, I'm now at 1 mistake high crossing the field. Doing pretty well too - until I get to the east end of the field and stare right into the bright morning sun. I try to roll out of inverted and get turned around, couldn't tell up from down with the spots in my vision, and flew her right down into the field.
While I was doing the walk of shame I was still seeing spots in my eyes. And the fuselage and wing were both noticeably out of shape when I got there. Not a good start to the morning.
At home that evening I got a fresh single edge razor and started cataloging the damage.
1. Firewall loose all the way around from impact
2. Right wing mount tore loose, and left wing bolt snapped off the top.
3. Bad things happened to the fuselage behind the wing mounts. I think this area was already weakened due to a poor hand hold when putting the plane into the car once - I heard a little crack, but didn't see anything out of shape so I went flying anyway. And here's the results.
I was able to peel off the dark brown trim where I needed to pull off the covering, so getting her looking new again is going to be easier
4. The inside of the wing looks a little trashed here. Need to rebuild a couple ribs, reinforce the trailing edge and flap hinges, rebuild the D box spar, and reinforce the leading edge strip.
Overall, not too bad, and some good lessons were learned. When at the field super early in the morning, don't fly towards the east of the pits. And when practicing inverted flight, go back to foamies for a bit till I get better
