Mini versions of FT planes
bartholomule
I had a few small motors and speed controllers, so I thought I would try making some scaled-down versions of some of the FT planes. I have played with making a few small self-designed foam planes to get a rough guess of how well the wings would work when scaled down.
The first of the planes that I am scaling down is the FT Old Speedster. I decided on a 47% scale because it was really easy to fit 4 pages of the normal plans on a single sheet of paper at this scale. Since the pod would be too heavy at this scale, I won't be making this version swappable.
Here's my incomplete speedster in the current rough form:
It may not be obvious, but due to previous experiments with larger wings on the full-sized Old Fogey and the other mini failures, I increased the wingspan by roughly 26% over a perfectly-scaled version, so that the middle section of the wing is 11.5 inches wide instead of the approximately scaled 9.375 inches.
I threw some weight on there to simulate the weight with the other electronics and gave it a little glide test. It didn't travel as far as I thought it should (too much lift and then stalled; needed some down elevator), but with the final parts and added weight of some mini landing gear it should fly just fine.
It is still a work in progress, but I saw that someone else was experimenting with a 48% bloody wonder, so I thought I would share as well.
Tjhogg
looks good at NEF Saturday I had a little talk with someone of the FT crew whom was carrying a mini viggen that david had built and a mini old speedster and it got me thinking about it also
bartholomule
I put the canopy, electronics, and control horns on tonight. It sits at 110 grams without the battery or landing gear (which I still need to make).
bartholomule
This one is the turnigy 1811 2900kv. I put a 6 amp speed controller in here, so it should be a little close to limits if I put the 6x3 prop on there. I'll put a meter on it to make sure I keep below 5 amps before I run it hard.
I'm curious to see how this flies. Getting to a bigger park is a bit of a challenge for me but I manage. There is one close to my house that has a decent sized field for a small slow flyer. I've been thinking of shrinking the Old fogey to see if it would work out there. I'd get a lot more fly time if it did (it's a closer park and that's where the kids prefer to go).
Please post a video of it flying if you're able! it's looking good!
-Jes
Jaxx
Try the Bloody Wonder with a Blue Wonder motor. It's a great slow flyer.
bartholomule
Sure. I'll have someone film me crashing it with or without the landing gear. We have some wind and rain moving in so if I get in early enough, I may see if I can sneak out with some coworkers to film it in the morning before things pick up.
ttprigg
My son flew the mini old speedster and loved it! Josh said it was 50% scale and he used electronics from a "retired" 'beast'. I just printed plans and made a HK order...
Flynn
I got a chance to fly that, and I was flying the 100% version that day. They flew exactly the same!
bartholomule
I tried to fly mine. With the 5x3 prop, it didn't have enough thrust to combat today's winds. The video my friend recorded is a completely underwhelming 7 seconds of flight before it was blown down when I attempted a turn, so I'll skip posting it until I actually get it in the air properly. The really thin strip of foam between the two halves of the tail did break, so I'll be reinforcing it before I try again with a 6x3.5.
