Mirroring plans
NightOwl
Hey guys, I’m going to make the Ft bronco and it requires I mirror a wing. What is a good way to mirror it. I hope I’m not an idiot and there’s a simple solution..
CrshNBrn
This is pretty common with plans. You can either flip the wing over and trace it on a new sheet of foamboard or put the plans on upside down and cut it out. Shouldn't be too tricky.
...What is a good way to mirror it...
Cut just outline of 2 wing halves, then flip one wing half over. On the wing half not flipped make all of the bevels & scores as on the plans. Then flip the plans over to make the bevels & scores on the 2nd wing half. I use a needle to poke through the plans & mark the foam where the score & bevel need to be.
mastermalpass
I hate it when plans don’t include both sides. I print all the sheets off, stick ‘em together then go “wait, where’s the other… Oh for F-“ then end up printing off a bunch of tiles, that usually include bits of the plan I don’t need to duplicate.
Tench745
If you're just printing out the plans and tracing, it's pretty easy to flip a template over and trace the mirror version as others have suggested.
I don't know of an easy way to mirror all or part a PDF in Adobe. Some, but not all printers have a dialog box to print mirrored or inverted. It's also possible to import PDFs into an image manipulation program like GIMP and mirror in there.
FishbonesAir
For me, make template from plan on posterboard. In this case, mark one side as Right, flip and mark back as Left - or Port if you prefer. 😁
Capt Fishbones
