The company I work for had an outstanding year so they were kind enough to give out nice Christmas bonuses. So what to do with this? Buy a 3D printer of course. I just ordered the Prusa MK2S kit so it will hopefully be here soon. Saw that MakerGeeks was also having a 25% off on gift cards so bought myself a gift card as well. I have 2 rolls of PLA that I got to use on our work 3D printer so I am thinking I may get a couple of rolls of PETG.
Nice! I'm sure you'll enjoy it! I got a nicer than normal bonus this year as well but most of it went towards dealing with my truck:
Hasn't been a fun December. I've had a mysterious coolant leak for a few months now. No puddles under the truck or obvious wet spots...but every few weeks I'd be low on coolant. Then finally about a month ago I got a visible leak that appeared to be coming from the water pump. Great. I just did that two or three years ago...well...had a friends neighbor who's a mechanic do it since I was too busy at the time. So two weeks ago finally had time and dug in to fix it. Got in there and found it wasn't actually the water pump but a hose on top of it that was leaking:
And it looked like the thermostat housing had been leaking as well. Apparently the guy I had do the water pump is like a computer. He does what you ask and not a bit more. So he didn't even check this hose or the thermostat while he was doing the water pump (things I always considered a regular part of doing a water pump.) He also didn't use the coolant I gave him and just filled it with tap water because I didn't specifically ask him to use the coolant. Groan. I had dumped it and refilled with coolant once I confirmed there were no leaks from his work...but apparently I never got enough replaced because things are rusty as heck in there
I wound up replacing all the hoses, the thermostat, the thermostat housing, the water pump, and some other little things that all told set me back $200 in parts. Put it all back together. Went on a test drive...and all seemed great. No leaks, thermostat was cycling, engine was staying cool...figured I was set!
Then the next day I drove to the gas station...and when I got out I smelled coolant
Looked under the truck and sure enough there was a leak - but now from the back of the engine.
Went back home and the leak only got worse and worse...by the time I went the 2 miles to get home it was a veritable waterfall coming out and I had a huge puddle. Things were dry at the top of the motor so I figured it had to be the freeze plugs. No time to address it that weekend so wound up having to ride my bike to work for a full week.
Last weekend I made time to pull the engine - and as expected found both rear freeze plugs leaking...one totally rotted away. Also found two on the side of the block showing signs of seeping. So $20 for a set of freeze plugs. And since I had the engine out $20 on some new valve cover gaskets since they had been seeping a bit. The truck is a 1998 with 237k miles...so...not surprising.
We managed to get the engine out on Saturday, repaired on Sunday morning and back in by Sunday evening.
But a few vacuum lines and breather hoses were old and brittle and needed replacing:
And by the time they broke it was too late to go to the store for replacements. So rode the bike again Monday. Got home on Monday and ran to the store for hoses...started finishing putting things together...and reconnecting the alternator:
Come on! I didn't even put a wrench on it! My fingers aren't that strong! Grrr. Ok. We've got a good alternator shop so I'll have them repair it. New alternator is $200 for this truck so should be more affordable. Wife dropped it off since I was still stuck on the bike.
Tuesday evening went to pick it up and the guy was all "I just got a new bag of those studs...and can't find what I did with them. I'll have it done tomorrow for sure."
Wednesday...back on the bike. Alternator guy "I still can't find them, trying to get more here ASAP". Asked him if he could just replace the (I assume) regulator unit they're part of...his answer "Sure, but those are $100 - replacing just the stud is only $25." Sigh.
Back on the bike Thursday...I swear it's uphill both ways, thankfully my office is only 1.5 miles from my house and while the ride in isn't too bad the ride home is definitely uphill all the way and no fun after a day of work. Once again though alternator still isn't done. Now he says he's trying to get some parts from someone else locally and should have it done by noon today.
If he doesn't...I'm just going to have my wife pick it up anyway and I'll figure something out myself. I'm not going without a vehicle for a long holiday weekend!
Long story short...instead of any new toys for me this year I got to dump about $500 into our old truck that I'd rather just replace but can't quite afford to yet. Mostly because every time I almost have a good down payment saved up something like this happens. At least this time thanks to my bonus I didn't have to dip into the new truck fund.
But I won't be getting to upgrade my printer like I had been hoping to either
Oh, also - MakerGeeks. They have good deals and decent filament...but...I'd advise against ordering specific colors from them. They don't generally keep stock on hand and just wait until they have enough orders to run any given color...so it can take a LONG time. But as long as you aren't picky about color their grab bags are a great deal and ship immediately.
