Aww geeeze guys thanks!
It would be my pleasure to share.
I peel the paper from the inside before assembly. After assembling the fuse i pull the paper outside the fuse. I take the power pod and cut it just after the first set of tabs. Mark the center then mark and drill your motor mount holes and hot glue a toilet paper roll where the motor goes. The power pod is then glued into place with wood glue or foam tac. Then i start taping off a rough shape on the nose. Fiber drywall tape works well, may have to use blue tape to help hold the fiber tape to the fuse. Tape off wires .Then find a pace you can make a mess. Its best to put down wax paper on the work area. Its time to start foaming. When foaming the can needs to be room temperature,shake well, start at the farthest point with the nozzle and pull the trigger and pull back as you go. Don't over do it it expands a lot. Mask off the inside at the back of the power pod so no foam get past.Let it set for 2 days if needed. When cured start cutting to the fiber tape and sand from there. Fill with light weight spackle sand and apply a few coats of water based polyurethane sand smooth apply another couple of coats lightly rough it up with a green scotch birght pad and paint.
As for the rear boom section i dont use a lot of foam just just run the foam along both lower corners.i block off the back of the wind on the inside so no foam get in. Cut out some of the foam in side after getting your shape. I leave the lower half of the inside. My rear servos are in the fuse above the cg on the wing.
I hope this helps im happy to answer any questions.
