VAALLEON
Re-tuning the unit for the 3 blade props. Amazing sound, much less noise. I was really amazed how much the flight characteristics changed with the new prop. Not sure I know the reason why. Anyway, the vertical flight, except the slow wobble, has improved unbelievably. After I fixed the wobble, for the fist time I felt in full control of the unit in vertical flight, which means that I can stop and go whenever I want during FPV flights. To achieve that I had to tighten the PID, which didn’t help much with horizontal flight. Now need to fix that.
This video has 4 flights: 1- PID tightened but not much, still wobbles out of control. 2- PID tightened, slight wobble, controllable. 3- Battery placed higher for a higher GC, didn’t help with the horizontal flight. 4- Back to original GC, the flight starts with loose PID, slight wobble, then soon after take off I change it from the TX and wobble stops almost immediately. Excellent control of the vertical flight throughout the flight when I did stop and go. But got into trouble in horizontal flight right turns. Another issue is that with the new prop the unit is less eager to transition to horizontal flight. Will need to do some aerodynamic changes along with some more tuning.
