Gluing in the bottom of the nacelle here - several spacer blocks wrapped in plastic are keeping the sides straight while the clamps are on.
And while nacelle bottom plate #2 is clamped up in the background, the first one gets a 3/32 thick plywood doubler installed where the landing gear will mount up. Wrapped up in plastic again so the Gorilla Glue makes less of a mess.
Not sure how far forward I'm going to do the firewalls and motor yet - need to select the motors first - so I'll probably leave the front of this open till I get further along in the build. Once I get a better idea how heavy she's going to be I'll start running motor calculations.
Next couple steps:
- Gluing down the top sheet of fan fold foam onto the center wing section.
- Cut the fuselage saddle for the center wing section connection.
- Glue nacelle bodies to the center wing section.
- Bending and test fitting the landing gear (once the rest of the wheels arrive).
- Make the rest of the interior hollows for fuselage equipment.
- Install fuselage spars and glue the fuselage layers together.
- Make another wing box for the outer wing sections.
Next couple steps:
