I'm wrapping the capacitor leads around the power wires similar to other examples I've seen on the other forum.
What is this supposed to do again? why the extra capacitance?
And I've learned my "new thing" for today! Now I can relax."if you extend the ESC battery leads too much over the stock length, you can get a nasty voltage surge condition that will blow up your ESC (this is why there are capacitors on the end of the ESC where the power leads come into it).
So I don't lose this later, here's the center of gravity calculations
Shooting for middle of the road 10% static margin a reasonable and stable starting CG for the maiden flight.
Do you think you will bunny hop it at first? Or just go for it on the maiden?
or just bring an outer wing panel to make everybody droolThanks guys!
Yeah, great idea on the liquid tape @PsyBorg . At 6s voltage across those puppies, I suspect they would explode quite nicely I'll be pulling that esc back out and giving it a brush before re-wrapping with electrical tape - I don't have any shrink tubing that tiny.
The shocks compress... a lot. I've been adjusting the springs tension up and am about 1/4 of the total adjustment level, but I need to do some more. When the outer wing panels went on with the wheels for the first time, the shocks bottomed out
I'm thinking to pass on bringing her to the club meeting today. That room at Monster Mini Golf we're using isn't that large, and the wife has the car I'll be transporting her in today - and probably won't be home in time to switch vehicles and get me to the meeting. So I'm going small for the show and tell and bringing the FrSky X-Lite transmitter and a Tiny Whoop instead Maybe I'll toss a picture of the FW-42 into the presentation though...
There are heavier springs available as well as thicker oiks that can be used in those shocks Jon. If I remember correctly they were stock from the original buggy before I frankensteined it into a monster buggy.
Amain will have both stiffer springs and various shock oils if needed.
Looking good! On those waterslide decals... did your camera mirror the image or are they printed that way? I'm pretty sure if they are like the ones I've used you print normally, seal the outside with clear coat or decal sealer, and then soak them to remove the backing and then apply. If that's the case then then I think these would be mirrored
Love the insignia!
