PsyBorg
Wake up! Time to fly!
I don't see that working so well with something over 20 pounds!
What? You has no faith in gimpy n lurch having the strength to chuck this in the air?😉
Just funnin guys.
If you do a glide test please record it as I have never seen anyone try to hand launch a canard that weighs quite so much!
It could be spectacular and very entertaining!
Have fun!
Oh yeah - and the inevitable hospital visit too!
Nice! Eager to see how it comes out. What is the cure time on the epoxy? How long do we have to wait to see it?
I've seen folks use an air compressor and a thin nozzle and try to get some separation that way. Drilling into the mold in the front (likely where it will be trimmed anyway) and using compressed air may work too. I do wonder it using heat might crack the mold. You might also consider cutting the cowling in one spot so you can flex it and get it loose, then going back and putting a strip of FG on the inside over the seam. You'd still have to deal with the seam when you prep for paint, but it might make it easier to get out.
Just a few thoughts.
Inside molds are really tricky. Looks like you're getting the hang of it.
You might try building a couple of fake cowls with foam board, remove the paper from the outside, fiberglass over the foam and then remove the foam. Foam separates pretty nicely from fiberglass, and if it doesn't, just hit it with some acetone. I'm sure you can whip up a couple of foam board cowls in a minute or two.
Nice!It would require a lot more finish work to fill and sand the weave on the cowl that way, but I don't have to make a mold which is a pretty good trade off.
Nice!
What weight of cloth are you using? A couple (three) layers of 0.7 oz (or there abouts) would do the trick and the weave is so small, you could sand out the top layer pretty easily. That or the old light weight Spackle.
Just had and idea that, not that you should do, but something I should try. If anyone following this thread has tried, I'd be interested in knowing the the outcome... 3D print the inside mold, overlay the mold with plastic wrap or some barrier, wet out fiberglass overlay and cure under vacuum. I think this would make a really thin, light, form-fitted cowl.
