Help! Motor and ESC question
Flyingcollins
I have a 2212-6t motor with a 30a ESC and a 104.5 prop. Does anyone have a recommendation of a speed build kit that would work with that power system.
quorneng
A 10x 4.5 prop is much to big for a 2212-6t. it will likely overload the motor and/or 'fry' the ESC.
Hobby King recommend a 7x4 on a 2s battery or a 5x5 on a 3s.
As the maximum current the motor will draw is 34 A they also recommend a 40A ESC.
With the right prop you might get away with your 30 A ESC but I would not chance it myself.
Site Moderator
The FT Scorch would be perfect. The Simple Cub would also work, you would have unlimited vertical.
Bando FPV
The 10 inch prop is a bit big for your power system. Any trainer like plane in the power pack b or c range should do fine.
Brett_N
Way way way WAY Way too much prop for 2200kV - it'll smoke the motor OR the ESC or BOTH within about 30 seconds. Trust me, I know that from experience.
10x4.5 is almost too much for 2212 1400kV motors (ask me how I know that too...)
You want an 8x5 or 8x6 Slo-Fly for that motor. Even down to a 7x6. Either of those in a pusher are a good choice for the Explorer.
Site Moderator
I agree with @Brett_N, if it's a 2,200Kv motor, 10" prop is way too much. You will destroy the motor.
If it's a 1,000Kv motor the 10" prop is about right.
Flyingcollins
This is the combo from Wish
