Hi Flight Test Forum
I am setting up an esc and motor up for the first time - but the motor will not start up when the esc is powered up - makes a series of beeps that weren't documented in its manual.
I have followed troubleshooting advice:
-Make sure the throttle and throttle trim is set to zero
- Switch the transmitter on first
- The transmitter and receiver is properly linked - tested with a server
The beeps played are as follows:
High(slight pause) high-low-high-low-high-low-lower. (I see sound/video can't be uploaded, so here's my typing attempt).
I got the esc, battery and motor as unused spares from work so it may be that there are issues in any one of these.
Any help would be thoroughly appreciated!
