Motor size? Diatone 1105 5500 vs Emax RS 1106 II 6000kv
outthayr
After reading many things about choosing the right motor, I've narrowed it down to these two options (basically the two things I could find in stock).
Building on a HGLRC Sector132 frame with a MICRO LUX V3 F4 stack. Battery 450 and 650 (3S-4S), and will have an Insta360 GO. Haven't done the full weight and calculated the thrust - pretty sure either will get the thing in the air.
My thought was the 1105 may be better for "cinematic" flight, and the 1106 may give a bit of speed and ability for acro? Thoughts?
Thanks!
Does this mean it won't perform well with a 4S battery? *RS1106 6000KV is a versatile upgrade motor for 2s-3s and well suited for those wishing to spin heavier 4 blade or 5 blade propellers.
*My first thought was to use the 1105 and I see now 6000kv would be too high for the 4S - always helps to read a little more!
"Corpse"
My tinyhawk freestyle runs 1103 7000kv motors on 2s and it can spin a 2.5 inch prop just fine. Considering you have a larger motor, you should be fine. 1106 might be better though.
