Mount for Detrum BM3515A-KV1280
wassup guys, im having trouble finding a mount for my Detrum BM3515A-KV1280, i dont have the dimensions of it but its bigger than the common motors..Was seeing if anyone has the some motor i have and could help me out on what mount this goes on..Im trying to put it on my slow stick..Yes i know its overkill but hey that's the joy of this hobby..any help will be appreciated thanks guys!
ps heres the link of the motor i have if it helps http://www.hobbypartz.com/60p-dy-1041-motoresccombo.html
thanks again guys! have a great weekend!
jetpackninja
More combat please...
I use these for 28mm motors on a slow stick
http://www.hobbyking.com/hobbyking/store/__5307__HXT_Alloy_Composite_Stick_Mount_20mm.html
Not sure if they are gonna be strong enough or if even the the mounting screws will line up with the motor you linked.
I've seen mounts like this one adapted for putting big motors onto slow sticks.
http://www.hobbyking.com/hobbyking/store/__6332__Wood_Stick_mount_for_foamies_10mm_.html
What are you trying to do with the slow stick?
Something more like this: http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=12921
Or Like the DT750 is what I would recommend for a slow stick
#3
thanks for always coming thru with the help Ninja! I am kinda getting bored with my slow stick, wanted to make it much more aggressive, pretty much take it to its limits lol..anyways ill look into those suggestions you made for my slow stick...thanks alot again Ninja!
#5
BM3515A-KV1280 Motor Mount
I have the same motor and I believe that the diameter is 35mm and the shaft size is 5mm. The spacing between the holes is 17mm. This is a big motor. I'm not sure the 28mm mount will work. Here's the link for the specs from the manufacturer.
http://www.dynam-rc.cn/Products_view_121.html
I'm also looking for a motor mount if anyone can provide recommendation. Thanks
