The fuselage work starts off very quicly, with the formers attaching to the bottom plate. Then the sides and a few trim pieces are added. Unfortunately, I forgot to slow down and take a few pictures along the way... So here is about half the work already done.
Next up is the turtle deck. After the glue dries you sand the deck sheets flush with the center piece, and then cap it all with another piece of balsa which is then sanded to shape.
The battery and servo cover is next. The sheeting is applied flat, then wet so it'll bend without breaking, glued, and sanded.
The front wheel cover is almost finished, and just needs a little final sanding to shape, and to smooth out a few little ridges.
After the battery tray cover is sanded and test-fit, the excess plastic around the canopy is removed. It still needs a little fine-trimming, but it's getting close. The pic makes it look like it's a little shaded near the top for some reason, but it's nice and clear all over. In the background the elevator halves are curing after being epoxied together.
